Inaugural RTH ends very badly
I have heard a couple of times that you can't take over control once you have hit fail safe. Is this true? I think it's vital that you should be able to flick it back into atti and carry on flying.
Regards,
Gunter.
What a day. We have been steadily tuning the GPS hold on our Cinestar8. Although the WKM would be quick to attain a GPS fix, like others, we had been struggling with the counter clockwise toilet bowl in GPS mode. First we systematically worked our way through various gain combinations with minimal success. Things improved considerably when we moved the GPS down the boom, roughly 3cm
closer to the center plate? We resumed testing today hoping to iron out a slight but consistent yaw...then we fine tuned gain settings to try and perfect GPS. It wasn't perfect, but it was very good....a real pleasure to fly in GPS mode.
We had one battery left and decided to try our first RTH flight. Our TX is the Futaba T8FG Super. We tested the fail safe on the TX in the software and it worked fine. The plan was to climb to 30 feet in GPS, turn the TX off and watch it go through the RTH process. If things went poorly...we would turn back on the TX and switch from GPS to manual and then back to Atti mode and take back control of the Octo. When I turned the TX off, the Octo started to toilet bowl and climb slightly, we wanted to give it a chance to RTH and patiently/nervously watched as it picked up speed and continued to toilet bowl in a wider circle. At that point I elected to cut short the mission and resume control by turning back on the TX and switching from GPS to manual to Atti. I expected to have control, but watched helplessly as the Octo spun out of control while I desperately wondered why it wasn't responding to my stick inputs. I don't have a lot of time behind the WKM and am more accustomed to the responsiveness of the MK. At this point things are mostly a blur to me. My partner says that the octo performed two pronounced yaws while it was losing altitude, and that at one point I was nose in and the bird was flying towards us. It then banked/yawed away and circled down into its final decent. At this point a crash seemed imminent and I tried to cut the power to limit the speed at which it would smash into the ground. Our beautiful bird crashed sideways into the ground carrying our GH2. At that point I was able to cut the motors and heard my buddy say "Lets hope we can salvage something."
We took the long walk to the wreckage, as we approached, things looked bad. Parts of the frame/gimbal were twisted/crooked...but luckily
nothing was broken. Can't say enough about the Cinestar frame and gimbal...top notch to come through that crash with no damage. Our old AV200 would probably have been a pancake. Our GPS rod was intact, our bare HDMI to composite converter was intact. To early to celebrate, but we may have gotten very lucky. One broken prop, and somehow the record button on the GH2 got damaged. I was in shock. We tried to understand what had gone wrong. I explained that I never felt that I was controlling the octo after turning back on the TX. Seems silly to not know....but we hypothesized that maybe when the bird was nose in, I instinctively corrected the wrong way and accentuated the bank instead of correcting it? This would give me the impression that the bird was not responding to my commands, leading to more drastic inputs, increasing the loss of control. What a sick, horrible feeling. At first I was pretty sure I had no control, my partner asked me to relive the flight, the more we talked the less sure I was...did I panic and freeze up? Reminded me of those stories of an experienced detective convincing an innocent suspect that he had in fact murdered someone. "OMG, maybe I did do it?"
Why did the octo react so erratically when we turned off the TX? Why didn't it return home? My partner asked if I was
sure that I had GPS lock when I took off? We typically get GPS very quickly...did I assume it was on? What are we going to do now? We brought the bird back to the shop and started the autopsy. In our experience, user error is the likely suspect. My first mistake, was not being 100% clear on what the protocol is for WKM RTH. I had read various posts, thought I had an understanding....not good enough! We reread the manual...I'm still not sure. Do we have to go to manual mode? Atti mode? Or does the TX reengage when you turn it back on? If I had not waited for a GPS lock and the WKM was unable to locate home, would it hover and then auto land, or just get all squirrely and crash? Was there a delay between the time you turn on the TX, and the time it will acknowledge input? Did I rush the GPS through Atti to Manual back to Atti sequence while the TX was turning back on? Is this even necessary? We thought about it, reread the manual and my partner tested the TX sequence looking for clues. He found that when the T8FG Super Futaba is turned back on with the throttle engaged, there is a safety feature, "Throttle position warning" that asks you to push a button on the display screen in order to disregard the warning and transmit. So for anyone out there who are still learning about these things,
make sure you turn off "Throttle position warning" safety feature before you attempt to turn off your TX and prompt RTH.
Lesson here is to be 100% prepared...and not to become complacent about things as you get more comfortable.
Anyone have any theories other than no GPS lock for the erratic RTH behavior?
