Is anyone using a Wookong or A2 with the graupner PPM signal? I am using a MX20 and have one small question that is baffling me. I have a new install with Wookong and I am testing the copters response controls with the copter weighed down by sand bags with just a little bit of slack so I can see the copters movements. One thing that is not making any sense to me is that for me to get the copter to actually roll left I have to set it up in the software so that Aileron slider goes right and vice versa. I can get the copter to roll left when I stick left and the same with the right roll but only if the Aileron slider in the software is reversed. Meaning that if I stick left with roll the slider goes to the right, and when I stick right with roll the slider goes to the left. Everything else is correct. Nick forward and backward is correct, throttle is correct, and yaw is correct. At first I was thinking I had the motors wired wrong but I am positive they are wired in the order of 6,5,4,3,2,1,8,7 from top to bottom.
So the copter is responding the commands like it should but only if the roll slider is reversed of what you would think. I am using SUMO 8 and have the cable coming out of servo 8 on the receiver.
Anyone have any idea?
