DJI s900 and futaba 14sg remote
Skyshots
Hi All,
I recently purchased a Dji s900 with a2 flight controller system but I'm having an issue getting the remote to register on the computer.
I currently have solid green light on flight controller indicating the bind is good but when i plug the usb in from the led i can only see that it picks up the multi rotor not the remote. I now get a beep that does not stop every second or so with the motors twitching very slightly and all led below motors illuminate on and off with beep.
Could it be a set up problem fro the remote?
I am unfamiliar with fUtaba and unsure if i have taken correct step to set up remote.
Tahoe Ed
How have you set up your Futaba? Is it in Airplane mode? Channels 1-4 and 7 are preset in the A2 for the sticks and mode. The rest you have to map. You also have to calibrate your Tx before use.
Skyshots
I have set the remote up as a multi copter i assume this is incorrect and i must set it up as an airplane rather? I have no control on computer screen doesn't read as DR 16 says none even if i select DR16 it still projects "none" i know the bind is solid due to green solid light.
once i can see remote on screen calibration can begin on the other channels.
Skyshots
The problem was the remote being set up incorrectly. I now have an issue on starting her up. She is getting power to the motors but i can't seem to get the blades spinning is there a start up procedure to follow? There is very little on the internet about this once you buy it. I come from helicopters.
