DJI NAZA V2 with Turnigy 9x Transmitter - PROBLEMS & PROBLEMS
I just meant the actual landing. I feel most comfortable landing in ATTI for some reason. I know a lot of people use GPS for the landings. Just not my comfort zone.
And I have the Taranis speaking to me for count down too. Priceless!
dan123
Thanks for all the responses it now works fine.
I am looking at getting a FPV set up and would like some advice.
I am looking at getting;
Sony 700TVL 1/3inch CCD FPV camera
Boscom 5.8ghz 500mw 8ch wireless av transmitter - T5352
Boscom RC305 receiver
Just wounding if any one had experience with these products or could recommend anything better? Not looking to spend a fortune.
Also would I be better off running the camera/transmitter off the same 3s 3300 lipo that powers the f450 quad or using a additional battery?
Can this system show the remaining voltage of the quad on a monitor?
Can anyone recommend a half decent in-expensive monitor?
Finally is this system also compatible with a Gopro hero 3+ if I ever decide to use this?
Thanks.
You can run the FPV off the flight battery, but obviously it will drain it quicker. This gear shouldn't pull a ton of juice, but you'll have to see if your flight times suffer much.
To see the voltage, you'd need an OSD setup. DJI makes a couple to choose from, as well as many others available.
The GoPro can be used, but you'd need a special cable to connect to your system. Check GetFPV or readymaderc - they carry all of that stuff.
