I finished my mods to the Coptersky GoPro 2 axis camera mount. While adjusting the servos I accidentally hit the default value button which caused the servos to bind. I immediately disconnected the servo leads to the MU. I reset the gimbal values to where they were before and now I get only the slightest movement in roll and tilt and no response at all from the transmitter tilt switch. I have recycled the WKM and reset the controls again but nothing. I checked the servos attached to the receiver directly and they work. Any suggestions? I am traveling and brought my WKM Quad with me along with a UBEC. I have not connected it yet.
Right now I am at 30 and 35 for roll. I will reduce it back down to see if that helps. I think that there is a known issue that Sydney is working on. I am not sure if it was you or Ken that mentioned it.
Gary there is not much you can do with that lag accept run high speed servos and at 7.4 volts. Set you response volume with a small spirit level and it should give a good degree of stabilisation. It is heavily dialed in to the accelerometer but it needs a little more gyro to pick up that initial movement. At the moment we cant access that but soon I expect we will. The other problem that you have sounds like a deadband problem. If they are programmable servos then try a little more.
Gary, you're servo block set up, its apparent robustness and the results you appear to be getting to-date lends itself perfectly to what I want to do. Hopefully now that DJI have shown this interest the 'glitch at neutral' problem will become resolved. I will be more than pleased if you could PM me the parts list/details for this set-up. Thanks in advance.
David.
I don't have any lag, as my setup is using Hitec HS-7940TH digitals, and they are running on 7.4V, via a programmable CC 10A BEC. These also have the 12-bit, hires feature, so the action, even in my direct drive setup, is actually quite smooth (see this post...). The only issue I'm having right now is the hunting/drifting of the WK-M's gimbal outputs right at the neutral point. On a higher-end mount, like an AV-130, this effect is less noticeable, mainly because of the larger reductions in the tilt and roll mechanizations, but it is still there.
The good news is that I received a PM from DJI, and they are going to have somebody take a look at this problem right away.![]()
I am experiencing the same thing with my rig. I increased the deadband but it dosen't make any difference. I hope that DJI can find a fix for this soon.
/Jesper
