So guys,
Any updates so far?
SleepyC, what made you sell your Inspire??
It's not sold yet!
Few things,
1) I'm poor.
The FAA has taken 8 months + to process my 333 and it's still not here. Just found out it may be delayed another 60 - 120 days. I broke ties with the company I was working under (they charged WAY to much to use their 333) and since all the publicity, I can't get work to save my life without that damn paper work. Due to this and just a general lack of constant work I'm having to tighten the belt as if I don;t I'll soon be "Sleepy who lives under the bridge"
2) It's not a professional system because you can't depend on it. And by that I mean this. It UNTOUCHABLE when it's working. Simple, smooth, great images, 1 min to get into the air, long flight time.. it's Brilliant. BUT... the constant updates, the "If you prepair for a job at 11pm, but forget to turn you ipad to "airplane mode" and leave it charging over night for your job in the AM, there is a good chance that even though everything was good at 11pm, when you get to your job at 5am, the DJI Go App has decided to update overnight and then force a mandatory update to your rig, or even just a simple "warning do not fly update required" message. Nothing is more unprofessional than being 100% ready just to show up to a gig and your rig is no longer ready.
3) the "Smart" batteries are HORRIBLE. If you have not read much about the I1. The batts are awful. There is a firmware glitch that is a serious problem. I totally thought it was just a bunch of morons not doing things correctly and causing their own problems, but it is not.
First off, you can only fly a battery if it's 100% charged. Meaning if you fly and land after 2 minutes... that betery is DONE, as if you re-boot the system with the battery that is at 90% it may not calibrate properly in the system. (People will argue this, but i have experienced this) Then there is the cold weather issue. No matter what you do, there is a good chance the battery will go from 90-80% to 5% in 2 seconds forcing a mandatory landing or in some cases a crash. Again, i thought this may be morons, but I had a freshly charged battery, flew for 3 minutes and the rig went from 89% battery to 5% in a split seconds and forced me to land. Fortunately for me, I don;t fly past LOS, so my rig was not that far away and I landed. After re-booting the system the batt was once again at 89%. Meaning there is a firmware issue sensing something in regard to temp and causing a shut down.
There there is the battery conditioning. EVERY 10 FLIGHTS the batts must be "deep cycled" to 3.3V or less and recharged to 100%. The only way to do this is to "Fly them down", canceling the low voltage warning and "as DJI actually states" Cancel the low voltage warning and then hover 2 - 3" off the ground until your batt cells reach 3.3V per cel. Then land , let the batt cool, and charge to 100%. OK great,I have 20 batteries... now every 10 flights on each I have to spend 10 - 12 minutes "flying down " my bateries. I don;t have this time... how can a professional deal with this? Even teh $500 Smart charger that a company sells does not take the batts to 3.3V so they can be system calibrated.
So for those reasons, the rig is a joke. Not to mention system updates that come almost bi-weekly... and mind you if you had tuned your rig ann it's perfect (to get them to fly good AP you must tune the gains) when you update the firmware every week, it erases your custom settings... I know what your thinking.. write them down, and re-enter them! Yea BUT... usually after an update the settings are useless as they don;t feel the same, so you have to "re-tune" the entire rig...
THESE are my complaints...
