TooManyHobbies
I use 2 HP 47a server power supplies in series to power the charger and take full advantage of the output wattage. One thing to consider is the chargers max output and what it needs to attain it. The 820 requires you to have 28 volts and over 43a of current before it will output the full 800w. So making sure you have a power supply that will give you the full potential of the charger is important also. The PS you're looking at will not give you great results as it is under powered for the chargers potential, granted you are not charging 5s-8s batteries. I would look at doing a DIY Server Power supply conversion like what I did, It works great and I think I have all of about $75-$100 into my whole power supply system!
View attachment 5103View attachment 5104View attachment 5105View attachment 5106
But like tomstoy2 said "buy it right, buy it once!"
Good luck with your Hexa...
http://www.commonsenserc.com/product_info.php?products_id=2729
How about the next up in line, a scratch and dent larger model? 100% functionality.
$219.95....from $259.95.
Honestly I just want to fly the right way from the start..
Not having to worry that I don't have the right tools for the job. mentally priceless.
-when my noob brain cells are more filled of info, I can use these tools to the level of which they were intended for.
I dislike buying twice from decision error, unless it's small potatoes$$.
Why does TP website say 10.5-28.0V DC (40 amps max) for TP820CP?
Thanks guys.
