D8R-XP connection to Naza Lite via SBUS
AZflyer
New to multirotor and at a standstill with my build. Does anyone know how to connect the D8R-XP via SBUS (FrSky SBUS) to a NAZA Lite with GPS? The build list is:
xHover MXP 230 frame, SunnySky 2300Kv motors, 12A ESC SimmonK flashed, D8R-XP rx, NAZA Lite with GPS, Sony 600 FPV camera, Boscam 600 FPV tx, Minim OSD, Turnigy er9X with DJT module and Smartie parts board flashed wit eer. Thank you for looking.
if it's sbuss follow the sbus connection section of the naza manual..... it involves putting it in a certain pin and changing the software in assistant to match
AZflyer
Thank you, I have been following the manual but that is where the confusion comes in. I have been unsuccessful in determining if the FrSky D8R-XP is a JR type or a Futaba Type. Not sure if that makes a difference in SBUS connection but it seems to matter in the setup. Between the two (D8R-XP and NAZA) I have inserted the FrSky SBUS to CPPM module. I have jumped the signal pins 3 and 4 and connected the SBUS module to position 1 of the D8R-XP and plugged the other end (CPPM Out) to X2 of the NAZA Lite. Thank you for your assistance.
