Actually I just gave it to a technican man and get him to fix it for me.
I don't know what he does with the servo (for sure he made some changes to it) and when I plug it to the Gimbal with the same setting including the TX, it running like nothing wrong has happened.
I'm suspicious of all this. From the beginning it has all sounded like the feedback pot was not centered when the servo was modified to 360 continuous.
my guess is that the cable for the external poti, in case of the pan servos for the resistor had an issue. The technician probably took the servos apart refreshed the solder joints and things worked the way they should.
It seemed like no matter what you hooked up to the external poti cable it had no effect to the servo.
