Hi rwilabee,
four sources for carbon props.
http://aerobot.com.au/shop/all-products/36-aerobot-12x38-carbon-fiber-propeller-set.html, I think ken is using these
http://www.lcc-shop.de/index.htm go to propeller
https://www.mikrocontroller.com/ind...id=614&zenid=b68947d00d99cfa25d84986c7591c416 these are my favorite.
http://mikrokopter.altigator.com/xo...5-p-268.html?zenid=0ifbi542qe1p78m6c4sppshbv7 XAOR, never tried them the price hurts if they suck.
but there are a couple chinese products coming which i will check out.
Boris
When is it going to lift something into five buckets. You can do it.
I'm really looking forward to seeing the results of your prop tests on the CS6 (my frameset arrives today...). I have a theory that the reason some have had problems with wobbling on larger WK-M setups is because many are using larger diameter props, which are going to spin slower for a given amount of lift, and will have a greater amount of inertia that will resist speed changes. This might be the underlying cause of the wobbling effect. Anyway, like I said, I'm keenly interested to see your results.
I'm still researching motors and ESCs, and I still need to order a second WK-M setup, so mine won't be flying for awhile yet.
-- Gary
I am also curious what the actual reason for this is. it seems that on other FC's that dont require frame measurements to be input, the controller doesnt "know" what it is flying, it just tries to keep things level. The prop thoery makes sense to me, but the frame size does not. What would happen if you input a slightly smaller frame dimension than actual? Would that compensate for lag in some weird way? Curious why the Xaircraft and MK and a few others dont need these dimensions yet the WKM does.
Next I swapped to the Graupner 11 x 5 and got the best results so far, no surprise there, not quite as steady as the Y6 on the same settings but again the CS with just a bare frame, electronics, and 1 battery weighs much less than the Y6 did. I wish Graupner would make these props in larger sizes, I think they'd be perfect for this frame but the 11 inchers won't be nearly enough lift with any substantial weight attached.
I would think the MC would make up for the lack of lift by spinning them faster, so maybe they are at some sort of limit. Maybe running on 5s would give it a bit more"room"?
You are right, the fun is just beginning.I wish I could send our weather your direction, so you could get some more flight time in.
Just another "boring" 75 degree, clear and sunny day here. :tennis:
-- Gary
It will spin them faster but do you want the motors spinning props at 70% of max rpm just to stay in the air? Doesn't leave much headroom for corrections and you can only increase the voltage/rpms so much before something has to give, I'd rather it not be a prop or ESC.
The key to getting the WKM to fly well is to balance the gain settings against the prop/motor combo and most importantly the RTF weight. It appears the firmware has some sort of sliding scale that it uses to gauge how fast to spin the motors against how much weight is present, a large craft with a lot of lift and not enough weight is going to drive it crazy and produce wobbles. I'm willing to bet the people complaining the most about wobbles on big multis with WKM would see a huge improvement by either adding weight or going down a size or two on the props. I think I'll be seeing that effect on the CS6 in the next few days and I've got a couple ideas running around in my brain about the whole tuning process with the WKM, stay tuned...
This is not an input anywhere in the Assistant software that I'm aware of, for entering the size of the model. There is a screen for inputting the distances the IMU is mounted offset from the central CG point, but that really has nothing to do with the size of the model.
-- Gary
