Bowley
Hi Bowley, happy to help you i'd like to see some videos
I can suggest one more improvement, just in the case you will need to improve even more the performances, you should use aluminium linkages or bigger plastic linkages, more you make the connections rigid and more you reduce eventual jittering
one more improvement you can make is to have the linkage elements work more perpendicular, in your pictures i can see that they dont work aligned to the servo, this could produce problems in stability
wich electronics do yuo have? MK or Dij?
Hi Anaka, just noticed your reply there, it slipped by me.
Thanks for your suggestions,
I eventually managed to get some spare parts for the gimbal so I have gone back to using roll gears.
