DennyR if you check the rcgroups thread on the AQ developments on the gimbal etc. the last couple posts were only about winding motors and they mentioned also motor with more poles. Jussi considered that more poles could give a higher resolution or smoother movement. Also in the Rcrgoups there is a whole sub forum about winding motors !
Boris
which thread are you referring to Boris?
| 28 or 32 poles should not be a problem, in fact it would be an advantage in terms of smoothness and cogging tendencies. The SunnySky/DualSky motors would be my preferred choice right now for a bigger load." |
info starting here:
http://www.rcgroups.com/forums/showthread.php?t=1815204&page=24
rcgeoups quote "
<tbody>
</tbody>
