I have a stock f450 with naza and gps that will drift backward and to the right (drift is the wrong word, it flies backwards, i need about 16 trim on a 8FG for it to hold in place, it is very bad at start of flight but as the batteries run lower, the drift becomes less). I have had this craft and problem for about 6 months and just cant solve it. I have done 3 tear downs and rebuilds, moved/replaced some motors, removed all FPV gear/ landing legs, tried stock, APC, and Grupner props. i had used a DX6I but have switched to a Futaba 8fg to rule them out so its now down to just the F450 and Naza. The IMU calibration does not seem to work as I have done the bubble level thing, raised the back as high as 3 xbox cases and even tried raising the front for a test and could find no real difference after calibration. The compass calibrates with no apparent problem and once the gps was set for magnetic declination it flies straight, but the drift is so bad GPS will sometimes be unable to hold position. I have not contacted DJI or the dealer as the naza was an ebay buy in a different country. Pleases help, any suggestions or info is very much appreciated.
