For Sale Argonaut GNSS receiver
Do you think this receiver would meet your requirements
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
    0
Miquel Garcia
ARGONAUT is a GPS receiver able to provide affordable accurate geo-location: real time accuracy of 2.5 m and off-line accuracy better than 0.5 m using ARGONAUT SaaS (http://saas.rokubun.cat/). This is possible because GPS raw measurements are stored for off-line GNSS processing (PPK, RTK, DGNSS...). ARGONAUT will also register external events (CAMERA triggers,…) within microseconds resolution and decimetric geo-location accuracy. The embedded IMU allows for increased rate of navigation fixes as well as robust solutions in scenarios with impaired GPS availability.
Use case
ARGONAUT (watch video here) is specially suited for drone based photogrammetry, mapping and surveying, remote sensing applications, allowing the drone operators to dramatically reduce the number of ground control points to be deployed to obtain a good quality final ortho-rectified product. As such it has been designed to be plug-and-play compatible with Ardupilot-based controllers.
You can download the datasheet here.
