ZAxis
Hi Andy
The idea of the diversity box is to select the strongest signal from one of two antennas so there isnt much point in using two cloverleaf antennas at the receiver as they're both going to receive the same signal levels.
Use the circular patch antenna and a 4 element cloverleaf (skew-planar) antenna at the receiver. The patch will give you long range reception in the direction you point it and the cloverleaf will give you good 360 degree coverage closer in. The diversity box will choose whichever signal is the strongest. Mount the cloverleaf antenna a little above the patch antenna so one doesnt create a shadow for the other. The patch usually has a horizontal beam width of around 60 -70 degrees depending on the gain so try to aim it into the centre of the area youre flying into and raise the elevation by tilting it backwards about 15 - 20 degrees to account for the altitude you intend to fly.
Thanks for that.
My thinking for having 2 cloverleaves was to allow the diversity Rx to cope with multipath reception. We like to fly down in the woods as much as open country and trees will disrupt signal pathways potentially compromising reception at one aerial. It would then be up to the diversity Rx to switch antenna to ensure we get the strongest signal. Am I correct here ?
