Is it possible to use the pcb plate on the bottom facing down to put the ESC also facing down, near the battery?
So i don´t have to put the ESC underneath the motors and extend the power suppy.
Is there any inconvenient to that?
It seems easier to have the ESCs between the plate since that's where the motor wires typically come out of the booms. But you can put the plate however you like - there is no ill effects to it.
For what i know the ESC do not fit between the plates.
I was also thinking on putting the ESC underneath the motors, and use bullets for the power supply..
Does that cause any type of stress??
Sorry, you are right. It's been a while. I actually did have them between - but it limits the fold-able aspect of the frame. I did put them under the bottom plate for a while, on the arms near the center plates, and now have the under the boom. It raises the issue of the extended battery-ESC wire being too long, which seems to be debated quite a bit. Some say add caps to the run, others say it won't be an issue. I have been running it without adding caps, and haven't had an immediate issue. But I think the detrimental effects would be in the long term to the stock ESC caps anyayy, so may be too soon to tell...
Instead of desodering the wires from the ESC to put bigger ones, i was thinking on using bullet conectors 3.5mm.
It does no harm does it for the power supply?
Hi Starting a new Build soon with a similar setup
Carbon Nylon 12x4.5" 1245 1245R CW CCW Propeller OR DJI 10"
Afro ESC 30Amp Multi-rotor Motor Speed Controller (SimonK went with these because i saw someone that could fit them under the motors. i just think they look a lot neater
SUNNYSKY V3508 KV700 700KV 3-4S
Tarot 680 Pro Frame
Naza V2 + GPS
Lipo S3-S4
Any feedback would be good. I didn't go into much calculations on my setup just went with what was common
Not a good idea...you want to keep esc to battery wires as short as possible, extend the esc to motor wires if you need more length. Solder and heat shrink everything, the only bullets used should be the battery connection.(SimonK went with these because i saw someone that could fit them under the motors. i just think they look a lot neater
I like the esc under the motor for many reasons. The biggest is having the extra room @the center plate. If you are concerned about power loss use a larger awg from power supply.
You can use a bullet and put a heat shrink over it to help keep it intact. Or you could solder the bullet.
Static confusion (ripple affect) should not be a problem with wire in the carbon tube. Unless your talking about the wine.
