Another Cinestar 8 and WKM
quadcopters
Glad your getting somewhere now :) High timing may help further and Maytech escs might be worth considering as Ken has had great success with them I have 20a here but Im waiting on the Chinese New Year to end and then I will build another with 40a Maytech set to 16hz and see the difference.
I also think switching to a lighter carbon prop is worth a try as I fly my Droidworx AD4-HL with 12x3.8 Carbons and there was some improvement using the lighter weight props
Geoff
Used the settings Geoff suggested and with a bit of reduction in the numbers got the CS8 to fly the best ive ever seen it do so far. Wind was only about 3 MPH but before it would pitch and roll badly with the old settings. Will try APC 12x6 very soon and also 12x3.8sf. May try high timing as well. Notice that at this weight, and with the 13x6.5 APCs used now, it only pulls 60amps in a hover. Thats not even 8 amps per ESC and only about 150 watts per motor. Its not even breaking a sweat and the thing just has monster power as well which kind of tells me that maybe the HW 40amp Platinums are operating some where beneath there sweet spot and perhaps this may justify smaller props. This is a total guess on my part.
I just finished my CS8 and want to maiden as soon as I can get a break in the weather. My starting weight is about 5kg. Where would you guys suggest I start out with my gains for the WKM? Thanks in advance
-Nic
kuau
Hey Ken,
is there anyway you can post a picture of your droidworx AD6?
I would love to see your new layout in terms of IMU placement, Power dist. And GPS
thanks
steven
From observation the basic gain settings have much to do with how well, or not, GPS hold works. With high basic gains and the lower ATTI gains the large frames need, GPS seems to easily go into TB mode. Being able to lower the basic gains helps a lot, but two things I've found that seem to make the most difference, get the IMU measurements as close as possible, and get rid of as much RFI as possible. That would include things like twisting the motor wires for the length of the run between motor and ESC and eliminating as much non shielded and straight run wires as possible. Also, and I know some people doing builds right now won't want to hear this but, get the power distribution board out of the center of the frame and out from underneath the IMU. The IMU gives off enough RFI as-is, it doesn't need any help in creating more and having the main power distribution directly below in the center of things seems to do exactly that. On both the CS6 and my Droidworx AD6 I've gone to the same power disti setup and elimated a lot of excess wiring, both have seen corresponding improvements in GPS performance. Coincidence? Maybe, but I'd be more willing to believe in a reduction of interference so the GPS can do what its supposed to.
CS8 is in the air!
I have the CS8 airborne. I plugged in to view my gains and I'm surprised at how high they are. 383 383 300 250. I am experiencing a tail-wag with YAW and also altitude fluctuation when applying YAW.
Current setup is:
CS8 with 2 axis CS gimbal
Graupner 11x5
Avroto 2814-11s
Turnigy Plush 30A
Parallel Lipos. 4s 3200 mah
AUW 5KG (11lbs.)
The flight conditions were in dead calm air. How much adjustment should I leave on the gain dial for windy days.
