Ok managed to get the Tiger CF props on the Tiger MT3515-15 Motors today.
Warning though the thread length on the prop adapter does not go down far enough, and I had to use a make shift couple of m6 washers to get it screwed down for now.
Not ideal, but at least I had a try with them.
Flight was very different compared to the Xoars 15x5, first thing I noticed the CF props seemed to be quite a bit quieter.
Had to play about with the gains quite a bit on the first set of lipos, so couldnt really use them to compare as I was up and landing so much.
Put on the 10400 mAh 6S and got a good hard 17 mins HARD flying time, pushing it quite a bit. (Maybe slightly longer than the Xoars
They were MUCH more responsive compared to the Xoar, and responded quickly to any slight stick changes.
Are they worth the extra money, not entirely sure yet, the Xoars do seem to hold hover a bit more stable compared to the CF, but I might just need to play about with my gains a bit more.
One big difference was descending, they came down much smoother than the Xoars.
Just need to get a gimbal on there now, I thought I should have been in the first batch of Besteadys being sent, but nothing as of yet.
Did find these prop adapters but unfortunately it says that these prop adapters do not fit the MT3515
Anyone else know of a better solution than a couple of 6mm washers, as they weren't the tightest, and I dont fancy bringing the thread down a bit further.
