A2 Motor Test Failure
That might be the problem, the ESC need to be calibrated. The motor test uses such a low range that it might not even be allowing the motors to turn. I would calibrate and then try the motor test once again. Sorry but I have never hear of this issue before.
I have yet to be able to get the motors to move using the motor test.... I did recalibrate the ESCs using a futaba reciever, but I closed the end points up to 60% and now the motors will run...
To recap I inverted the throttle channel on the trans and made throttle normal on the receiver to get the CSC to work.
Am I stupid and missed the section in the manual on how to calibrate ESCs using your A2 as I can't find it!!!
deluge2
Using A2 for direct ESC calibration
May want to check out this thread from elsewhere:
http://www.rcgroups.com/forums/showthread.php?t=2126826&page=5
It contains the following exchange regarding ESC calibration using the A2 controller directly:
CG Photo: "I was able to calibrate my Tmotor ESC's using an A2 controller and Futaba 8FG radio. I used one of the four outputs. In the assistant I connected one of the outputs to the throttle channel. Then I plugged in each esc one at a time and did the calibration. Works great and no need to use a separate receiver."
Tahoe Ed: "Good to know. You can map D1-4 to F1-4 for the purpose of throttle calibration. I did not think of that. Thank you."
Steve
Thank you Steve and Blade strike your help is much appreciated !!
Chris
Steve
Thanks to Benjamin Kenobi, Gael, Carapau, blade strike, deluge2 ( Steve ) for your help and ideas. I just calibrated the ESCs using F1-F4 all mapped to channel 3 ( throttle ) worked like a dream !! 6 motors done in 2 goes!!
Thank you one and all!!
