So, I was puzzled about this last night after setting up my a2 on a test quad with 2.3.
I have not followed or even read the links posted thus far, mainly as I wanted to go by the book to see the outcome.
Firstly, turning off the Tx showed no 'rc lost' or other indicators.
Could not find anything in the manual to point to a solution so just set up the Futaba FS in the FS menu (8FG) like most of us have to do if using a branded Futaba Rx.
This seemed to work but I had a few issues - first one was that after testing FS a few times the A2 system decided not to see the returning signal, this was after about 5 Tx power of tests in the space of about 20-25 seconds, a power cycle of the A2 was needed to get the connection back.
I decided at this point to take out the FS on the Tx side as the last thing I want is an issue reconnecting. After doing this though the A2 now will always print up ' RC lost' when the Tx is turned off... Go figure, now it works without Tx side FS...
I'll flash the A2 later after I have put a few packs through the quad to see if the A2 initially needs a FS signal to the A2 internal Rx to be able to recognise when the Tx signal is lost, it certainly looks this way.
