I fly 12s on all my scale helis in pairs of 6s. Had a bitchen model, hughes md500 all done up, had been flying all day with multiple models and broke out the hughes. i did not check the voltage on my packs for some reason, felt confident that 2 i just grabbed were fresh. Well, one was fresh and the other was done...... hooked em up in series and lifted off....... got to the end of the run way and the tail got a wag, i had never seen that, right about then i made a turn for home and it LVC'd 150+ yards out and headed down...... it was far enough you couldn't hear the motor stop, but man could you see the affects. from 15 feet up and going fast and away i took her in, flared and went to survey the damage. the rotor still sat there spinning, never touched the ground, but the whole model was a total loss. bottom was flattened, ground off, inside completely destroyed.......
Moral to the story, if your gonna fly pairs of packs, you better have the patience to check each pack each flight or sooner or later theres a good chance it'll happen to you. I went three years, then "that day" Worst thing was i had it sold so it was a big hit to my brain. Made me explore multi rotors
