New antivib adapter
krleas
FPV Freak
New inovative product on market, special antivibration adapter with lockup system.
Extremly light in alu case with hexa screw 3mm mounting on top and bottom.
For payloads arround 1-2kg u need 4 pieces, for 3kg 6 pieces, for 5 kg 8 pieces.
This adapter completely eliminate all high frequencies from motors and props.
And when u land there is lockup system.
Dimensions:
- FI 25mm x 25mm high
- weight 18g
Easy to install, video with Cinestar comming soon.
SleepyC
www.AirHeadMedia.com
Very interesting. Please get some pics, and where are they available? Price?
Thanks in advance.
hexacop
HexaCop
PaNt
Dimensions:
- weight 18g
I cannot understand how it works..
Tomstoy2
Hmmm,,,, on the subject of bl gimbals. is it just me? Seems like every video I see pitch is pretty damn good, but roll is a whole different issue?
18 grams each? Not too bad.
hexacop
HexaCop
basically it is a silicone damper with its own case and it works in compression mode.
The inner shaft (arrow side) is formed like a T and sits above the silicone.
It has several advantages,
a) the silicone is used in compression and that is the recommended way
b) can be mounted easily
c) 100% secure as the silicone won't crack
d) save to land on it
I tried to photoshop something, I hope it is more clear now how it works...
hexacop
HexaCop
This is pretty early stages with the open source firmware we use and it was really the first outside test, there is a lot of tuning needed to adjust PID values and due to the weather it is hard to test outside. You see the second flight was much more stable even in dynamic flight, but in any case this is the future, servo driven gimbals are history.
PaNt
Have you tried the stock cinestar DAmpeners.. Why you think these are better??
Thank you!
Muunk
Way to expensive! Why do us multirotor users have to pay so much for a thing, whitch should only cost a 10 dollars?
PaNt
Because the know that you will use them for pro AP AV that you will earn money.. !So you won't have a problem ..!
Muunk, you try making your own part and tell us how much it costs you and how much you need to sell it for to make the investment worth your while. These things are not cheap unless you make millions of them.
PaNt
You know very well that some things are overpriced in this hobby.. !!!
No doubt. but as a manufacturer of small low volume products I appreciate what goes into making these things happen. The real problem is that we are used to China prices and that drives everything else down to it's level. I am constantly forced to adjust my prices based on what someone would be able to get if the went to China. But even those products manufactured in China take a lot of time and money to go into production. And that investment has to be profitable to make it worth while unless a company is using that product as a loss leader. And only huge companies do this such as Costco. It's simple, if you don't like the product or its price, don't buy it. But I had a guy actually get angry with me because I charged $29 for a motor wrench. I told him not to buy it. He was furious that I charged that much since he could go buy a wrench from Home Depot for $5. But he failed to recognize that I make 10 at a time, they take me about 10 minutes to cut and weld each. Then I have to sand them down, rubber coat them, and package them up. It is not worth it in the end.
