Sorry to be dumb, I think I know what a diversity board is, its something to wire two receivers to is it not? Is this in case one RX fails? is that a common occurrence?
Dumb Dave
PS iI am sure I should know what ARF is but could some one just prove me right! Its er....
Here the read out dave...
This handy little devices Allows you to plug into up to 4 Spektrum / JR Satellites into one output.
This allowing for true Multi Diversity switching with your 2.4 Spektrum/ JR systems.
To extend range and reliability.
Normal Working.
After switching on on the LED flashes fast, until a valid satellite signal is found. Then to the appropriate channel is switched and the LED goes out. (strongest one wins.)
If this selected receiver loses his signal, it switches to another receiver and the LED on the plate shines permanently, so that you know which one had a receipt loss. The LED can be deleted at any time with a short pressure on the connection key (up to the next error).
