Thanks Guys, well I have set up the dx6i to failsafe landing now at about 42%
I do have it on RTH (Return to home)
But I guess the main question was do I have it on the right setting? (GPS vs Failsafe)
i,e,Does it need to be on GPS or Failsafe to work?
When I tried it I had it on GPS, does that mean GPS only and RTH wont work and it will just land?
I attempted to give the slightest over 10% throttle and the throttle alarm activates when the DX8 is turned on so it wouldn't "allow" me to bind... I set the pre-set failsafe to RTH and when the DX8 was turned off in flight the quad motors didn't turn off as you are mentioning. The LED rapidly bliked yellow and the quad went into RTH failsafe so I don't know what else is supposed to be done...
LOL, sorry and just so you know im actually HAPPY with my unit so want to be sure everyone knows all coments are actually in a good mood
This is my last feature I need working because tomorrow my FPV comes in and "just in case" I get lost I would like some backup to get my grand machine back.
The rx is AR6115e
the one that came with it.
I want to also add that whne I put my Tx to failsafe the naza blinks fast yellos(Tx not found) put it back to GPS and its fine (gps working fine holds position fine)
thanks for the help
That is why you move the end point of the throttle from -100% to -10% and it will allow you to set the preset Failsafe. You were lucky because your were flying before you may have picked up the last throttle position. Most times, that does not happen.
When I enter the servo menu it's 100% & 100% for throttle.
So I make only the left value 10%? Or 90% which indicates minimum stick input is 10%?
There isn't a negative value
I am glad you are happy with yours. I have two and am also happy with mine. I am always in a good mood. Unfortunately the AR 6115e does not support preset failsafe. In order to get that feature you will have to upgrade your receiver. You can check the Horizon web site for more references.
Also check what is happening in Assistant when you shut the Tx off. I think that you will understand the difference. When I turn mine off, the throttle goes to 50% and the slider goes to Failsafe.
It takes an AR 7XXX and above that has a Data Port to support Preset Failsafe. The lower models will not. I picked up 2 of the AR7010 with satellite for $89 each which I think is a bargain.
