i can tell, that's the only reason i keep trying................
a motor, any motor is rated with a max watt. that is volts times watts (3s is 12, 4s is 16 just to keep the math easy) lets pretend a quad hovers at around 250 watts with proper props like 8" with 4s or 10" with 3s in your case, as you mentioned is written on the motor.
if you have a motor running 20 amps, 16 volts with 4s and 8" props, the same voltage going in the same motor but you change the prop to 10" and your overwight, your looking at a quad hovering at lets say 30 amps and 16 volts = 480 watts, sitting still. if we take the 480 watts and divide it equaly between 4 motors your running 120 watts a motor. tilt forward, amps start going up cause atti is keeping you from loosing altitude and the numbers go up higher and higher
this would be the same except split in 6 if a hex, higher numbers if more than 2kilos cause is all i know. but i log all this info during a flight and see in on screen flying fpv/ can download it later in a data recorder. without actualy seeing it on the craft we discuss is tough, but the numbers would be pretty close
