Some DJI Beginner Questions
stpfl
hello
i am not a multirotor beginner at all. i already have a octokopter from mikrokopter.de
now working on a hexa xl with a dji naza brain.
But there are some question where i cannot find any answer.
1) Orientation of Naza. where is front etc etc
2) does i have to make a acc calibration for a straight flight. i don't find anything in the manal
if naza don't need acc calibration like mikrokopter from where does naza know if the kopter is in level??
3) i am using a sum-receiver perfect matching to mikrokopter. the same receiver does not work with dji naza. what means S-BUS
are there different Systems?
thank you
hello
Page 7 of the manual.
2) does i have to make a acc calibration for a straight flight. i don't find anything in the manual
Not required.
Keep it level when you power it up.
Now I am not sure what you are talking about, sum-receiver? Do you mean a satellite receiver? If not I don't know how to advise you.
SBUS: http://www.futaba-rc.com/sbus/index.html
thank you
Hope this helps.
mailman35
also ive noticed that you need to have your radio turned on before you power up the naza. or else you get some weird responses. ( its also in the manual)
NEVER power up a RC controlled craft without turning on your transmitter and making sure it is set to the right model. You can be seriously injured if you don't.
With sum receiver he means PPM. So i guess you have a jeti. Could be that they update it soon and PPM in to the Naza and the WKM will be possible. At the moment you can use a S-bus or traditional receiver. So you dont have to change your jeti module in the graupner which i guess you have get a standard jeti receiver !
