DJI with FPV
Kilby
You should be ok with that positioning. I was mainly worried that you had the rx up front just above the vtx.
I set mine up so I had the RC rx up front (with a satellite) , then the vtx in the back with the GPS centered and up above all of it.
rwilabee
Here is what I finally ended up with to get the vtx antenna further away from the gopro so it wouldn't interfer with the signal to the ground.
Rich
Wavev
I have the identical setup and noticed white lights while after turning on vtx. Question.
? Are you using a power distribution board? And I didnt see a secondary battery to power your vtx. Is the main batter powering vtx and motors?
