building hexacopter with DJI WKM
paktazh
Hi
I recently bought a DJI WKM and want to build a medium size heavy left hexacopter can some one let me know where can I find a good hexa frame with good heavy left motor and ESc that work with DJI
Thanks in advance
Droidworx AD6 would be a good place to start, it can handle just about any combination of motors and ESCs you would want to use.
paktazh
ya but that is too expansive 700- 1000 for just a frame . Has anyone used the xaircraft hexacopter frame ? what kind of motor and ESC can be used with that in order to left 3 - 4 kg any idea ?
Sebas600
You said heavy lift... better get the droidworx
lift 3-4 kg needs 6-8kg total lift 6-8kg/6motors= needed lift per motor
quadcopters
Xaircraft Hexa frame will not lift 3-4 kg. Max prop size you can fit is 10" and that is leaving a tiny gap between props .
For the Xair Hexa frame I find it flys better with 8" and 4s lipo.
Geoff
paktazh
I mean total weight 3 or 4 kg include the weight of the hex copter as will
has any one used the xaircraft hexacopter frame ? Do u know the total weight that can left include the frame?
Hi Paktazh,
I missed you there for a while, i have a similar set up you may looking for: Grand total weight is ( AUW) 2.9kg-no room for expansion
it flys very very nice, i believe you have seen these photos already….! it flew three times so far , first test no camera, second test with the Go Pro HD2 and last with the Panasonic Camcorder I'm debating ,which one is better to do the Aerial Video….both are posted in youtube ( still looking for sweet spot Gimbal gain little bit of everything )
View attachment 2016View attachment 2017
Bit boring since it's my first Video: [video]www.youtube.com/watch?v=hh7Fh2T1MXM[/video]
……………………………………………………….[video]/www.youtube.com/watch?v=XzS2GP3DUF8[/video]
Both videos are trim down for short time play ( raw footage )
Shiu
paktazh
thanks bro can you tell me where did you buy the FRAME and if you kindly give me the link or the name of the ESc /motor /prep and and other item that u used for this except DJI since I got that
by the way i seen ur video they are both great very nice great job Bro need to do the same
Thanks in advance
Thanks in advance
Frame : http://www.foxtechfpv.com/full-carbon-hexacopter-foldable-frame-p-373.html
M
otors and Esc…http://www.clubheli.com
Gimbal ………...http://www.photoshipone.com
Shiu
paktazh
Thanks bro I know I asked u these question before but i lost those post and could not find them I just bought the frame from that site regarding the gimbal I already got one but regarding the motor and the ESc need to know detail since some motor and esc does not work with DJI and what battery did u use by the way I bought this mount http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=320812749340&ssPageName=ADME:X:RTQ:US:1123
is the motor t2216-kv 800? it is hard to read it om u picture
Hi Paktazh,
i have seen these Gimbal already with the 500gaui mounted ,( friend of mind bought it at http://www.flyinghobby.com all package good deal) since its a three axis it require bit of modification to hold tight , other challenge part for you is the Battery mount
i have modded the frame the Hexa,so no longer is foldable make sure you apply every bolts and nuts with the LOCK TIGHT ( blue )...
I think this is a one of the best DJI FC out there at this moment , when its come to the Motors and Esc ...! Very few it becomes incompatible but I'm not expert ...
Yes.. you are right its a 800kv Tiger motor and their Esc 30a both are meant for Multirotors.( excellent performance)
The Battery 2 x 5000 mah 3s flying time 12 minutes max .
shiu
paktazh
I will try to do that but regarding the wiring since i build a xaircraft v8 some wires are crossing and how about the hexa which wire should be crossed any idea
thanks
thanks
Crossing wires im not sure what do you mean by? just follow the manual you will be ok…. if you run into a problem you know what to do Multirotor Forums …Hallo..Hallo ! :)
Shiu
paktazh
but unfortunately the seller did not send me the DJI WKM manual I have to find out the electric configuration I build a xaircraft v8 a Gaui 500 they both had cross wired like red to yellow yellow to red but in the rest red to red yellow to yellow
just bought the 6 of
Tiger Motors MT-2216-11 800KV
Item Id: MT-2216-11
Your Price: $39.99
and 6 of
Tiger Motors and ESCs > Speed Controllers
Tiger Motors 30A ESC - 2A/5V BEC
Availability: Out of Stock
Your Price: $29.95
and these are what u got ?
Motor and Esc yes and yes!
regards to cross wires or ( colour codes ) do not follow like other FC's
Manual can be download from Dji web site any time full PDF VERSION i don't think manual comes with the package !
Shiu
paktazh
Today I bought 6 Tiger motor and 3 tiger ESc unfortunately they are out of stock I have to wait till they get 3 more and I did not find any other site to sell those Tiger ESC Does any one know some other sites for Tiger ESC . also Bro want to know what size Props did u use so I can buy that now
[h=3] [/h]
Props are APC 10x4.7 get some spare you never know….did you ask the Vender about the Esc's how soon put back into stock?
when i bought this motors and Esc's it took almost five weeks get to my door….it was a long story i made a short!
paktazh
I emailed him but no answer yet i try to call him on Monday by the way regarding the APC 10x4.7 Propeller
I have found few kind but they got diffident kind of number just want to make sure so I can buy the right one
[h=1]APC 10 x 4.7 Slow Flyer Propeller APC10047SF
[/h][h=1]APC 10x4.7 Slow-Flyer Propeller LP10047SF NIB
[/h][h=1]APC 10 x 4.7 Slow Flyer Pusher Prop 10047SFP[/h]Does it matter which one I am checking these on eBay
thanks
thanks
if i were you…. five push... five slow fly ( five of each)
