DennyR
You need to get in tighter to test a camera mount properly. the best way is to use a laser pointer on a wall that is twenty feet away.
Where are you guys getting them from? I had pre-ordered direct with George last year, but cannot get ahold of him. Want to buy from a retailer that actually has one if possible instead.
looks good ! what voltage you you driving your servos at. And were did you mount the picloc, like recommended from george ?
I wonder what i am doing wrong :)
holco
Maybe this helps,
Hi Holco,
thanks i dont have the Av130 mounted any more, but i will again on my hexa. My settings weren't to far of for the AV 130 like you have them now. Hmm but i cant get the same results certainly not on fast movements.
Skysurf
Could someone provide me the dimension of the Picloc 3x please?
Jesper
Guest
well as of this morning we sold all out
we got 5 more comming for next week , so if anyone needs one pre order now to get them.
you can cancel anytime and get a refund if you can get them somewhere else instead.
Sandor Kruise
digitech.nl
holco
Hi Boris,
Like I previously put, [FONT=verdana, arial]you have to change the roll pot for a 3 turns, if not you can forget it to get good roll response!!
[/FONT]
Also set your servo refresh rate to 400Hz.
I uploaded the tilt settings also next to the roll settings.
regards,
Mario
Hi Holco,
Ho Holco,
thanks I will consider for my AV 130. I am not far off from the settings so i guess it could really be the poti concerning the roll axis. But like said i have a different goal in my eyes than you have. I dont want the gimbals to work perfectly concerning rough and larger movements. I want it perfect with no wobble no noticeable acceleration jitter on maybe 0 - 10 degrees or even less change of the copter. I fly my birds with dual rate 80% and expo 30 % so plainly hovering into directions.
And Result like these:
http://vimeo.com/32571891
I havent gottten up to know with any gimbal were the servos were on, either WKM or MK stabilization on. Shot with a canon 500 no post anything except fad in fad outs.
Very nicely done holco. I really like your synchronized video mesh up !
It would be cool to see an on board take with the servos off on the gimbal to get a feeling how much the picloc and AV 130 compensates !
