Introducing The Splash Drone Pro
UrbanDrones
Distribuited by:
UrbanDrones.com
Located in South Florida
The Splash Drone has arrived. The Splash Drone is an aerial camera platform that is fully waterproof,
100% buoyant and can safely be used in aquatic environments. The system arrives completely assembled and includes a waterproof camera stabilization gimbal (compatible with GoPro 3 and 4) a telemetry
equipped, remote control radio system and a video transmitter: FPV even when the camera is underwater. The Splash Drone Auto can be flown from a phone or tablet, has way point navigation and can automatically follow a moving subject. This is the perfect drone for anybody who loves water sports or finds themselves flying over water often.
Features
1. Waterproof Camera Gimbal: A 2 axis camera stabilization gimbal allows the
pilot to manipulate the position of the camera during flight and ensures
smooth video capture.
2. App based control: Allows the pilot to fly the Splash Drone with a mobile
device.
3. Follow me mode: Automatically follows a moving subject. All the moving
subject needs is a mobile device.
4. Point Of Interest : Automatically keeps a subject in frame.
5. Autonomous Mission Planner: Click waypoints on a map and have the
Splash Drone execute a predetermined flight path.
6. Return Home: The Splash Drone will automatically ascend to a
predetermined safe altitude then return to its take off position if radio
contact is lost or if the pilot activates this function.
7. GoPro Dive Case: Seals and protects GoPro from the elements. Feeds live
video directly from the GoPro to the video transmitter.
8. Integrated video transmitter: Transmits a clear video signal for up to 2
miles.
9. Telemetry flight control and remote control system: Telemetry at the palm
of your hands, displays Splash Drones location, altitude, distance and
battery status.
10. Payload Release Mechanism: Can drop a two pound payload at the flip of a
switch
11. Attitude Stabilization: - 12 axis guidance auto adjust altitude providing a
high level of maneuverability.
12. Auto Landing: The Splash Drone can automatically land itself when battery
drops below preset levels.
Tech Specs
Body Frame Super strong and light ABS material with sealed design.
Product Size Diameter: 500mm, Height: 120mm (without landing gear)
Propeller, Height: 230mm (with landing gear)
Product Weight Frame weight 1150g, Max flight weight over 2500g.
Brushless Motors 690kv waterproof treatment brushless motor
ESC 40A ESC
Propeller x 2 sets Self-tighten Carbon Fiber Propeller (1set)
LiPo Battery 4S 4200mAh LiPo Battery
Inner Size 160mm×160mm×55mm
Remote Controller 8 Channel Telemetry Controller
Flight Controller Smart flight control system GPS that includes OSD module inside
Intelligent Circuit Low battery detection, dual voltage regulation circuit (5V & 12V).
Top Cover Sealed cover*1,Nano materials water vented cover*1
Flight Time 4S 4200mAh LiPo: without load 20 minutes
Indication LED 4 bright direction indication LEDs with low battery warning function
Hanging Screw 4 threaded mounting holes and adapter plate for mounting the Gimbal
Landing Gear Carbon Fiber quick-release landing gear
Balance Charger Compact design, high efficient, smart balance charger with built in power adaptor
Alloy suitcase Customized, strong alloy suitcase to for FPV and RTF SPLASH DRONE.
Distribuited by:
UrbanDrones.com
dazzab
Fantastic! Really nice job. Some time ago I had to hack together a similar setup which was a real pain. It's great to see someone has finally put the whole package together properly.
dazzab
In case anyone is interested here's a video of the Aquacopter I hacked to add a gimbal. The little container on the top is where I put the APM 2.6 flight controller as the inside of the copter was getting a bit tight and hot. It works well but as you can see it's not nearly as slick as the Splash Drone. I'm really impressed that they have put this together. I'd love to test one. If anyone gets one make sure you post a review.
ash
Your aquacopter looks very impressive. I would love a Splash Drone but can't afford it so I'm going to try building my own by 3D printing a housing and using the bits from my DJI 450. I believe the DJI motors are OK in water. What I'd like to know is whether my Tarot gimbal is waterproof, as it's only 2 brushless motors. I would have to seal the cables and connectors, of course. Any tips you can give me? Thanks Andrew
Rahulkumar
