First Flight under belt, started off rocky.
Finally felt it was time to fly the project. Took it to a local field and set it down. Throttled up gently. Quad tipped over.
kept trying to throttle it and could see it was just going to flip. Again and again and again. Was really bummed.
Friend of mine sees me and walks out onto the field (saw my truck) and without knowing a single thing about quads, see's there's something wrong. Motors were all turning the right way, everything set up and calibrated correctly. Having nothing to loose, i took my friends advice and went at it again. Think popped right off the ground & few
AMAZING!
It was blowing close to 20 knots, but I was tucked in behind some trees and had just planned to hover a bit. Took off in manual & flipped it to GPS mode. I've seen flight videos, but I could not believe how the quad holds itself like that. Very cool. I could see the wind pounding on it & it fully took the abuse & managed to keep position. I felt the real 450 quad acted almost exactly how the simulator represented the gaui 330-x in Phoenix simulator (before they updated the software & now doesn't fly anything but manual mode, which i guess is good for practice.) I did not test the failsafe feature yet. Need a little bigger field and little more experience just in case I have to flip it out of failsafe and bring it home manually if anything happens to the GPS signal. Maybe in a dozen or so flights...
The 450 with the Naza V2 GPS is actually easier to fly than the simulator & so much easier than the toys i've been messing with (ladybird/proto estes). So all those things really helped. Money well spent.
Had a fully successful flight and was super fun. I didn't keep track of the time, but I'm pretty sure it was over 10mins. I kept checking the battery voltage with a battery medic and flew it til the cells were all near 3.7v. I also had a voltage alarm on the battery.
I read hundreds of pages and posts, manuals and youtube vids to get here and I missed a few newb tips that I think are obvious to some, but won't be to others:
1. Props: I thought all the props were the same. This was really stupid in retrospect and super obvious -- but I didn't read across the topic anywhere (missed it, or it's actually not there). To state the obvious, the props are not the same, they are marked per their rotation (duh). Make sure the ones marked with an "R" are the ones that spin clockwise.
2. Sticks: on takeoff, don't touch the elevator or the aileron. just the throttle. Even after I swapped the props to their correct locations, I felt the quad was gonna tip on takeoff. I didn't realize that I had developed a bad habit with the sim -- having some stick input for both elevator and aileron upon takeoff. Once I left my fingers off the stick completely, the quad just popped right up.
Anyway, a huge huge thank you to Bartman and the rest for all the help and support through the build. It would have taken months and months for me to do this without this. The process was so much nicer than buying a RTF and just heading out. I feel more confident now because I had to put it together -- it forced me to better understand the details that might otherwise go completely over my head or unnoticed.
On to the next build! 550 with a gimble/gopro/Voltage telemetry/FPV
