XAircraft Help needed for config V8
vadmcse
Can you post some screen captures of the XA center?
Go page by page and capture every page, maybe i see something wrong.
vadmcse
Are you testing with 4 or 8 motors?
The custom profile you are using, was created using the "quick flight style wizard"?
I see you have the flight mode switch in GPS ATT mode, put it in ATT mode, and remember to test ONLY the FC and AHRS. The GPS and AUTOPILOT, should be disconnected.
vadmcse
BTW, i see in RCG that you ask about changing to NAZA.
OK, you only have to connect M1 to M4 and the receiver.
NAZA only accept 6 motors, so you can't configure it as OCTO.
First im trying to fix this... if it doesnt resolveanything ill make the switch
About the naza i tried to do that once but no powerto the naza
vadmcse
Ok, let me make some tests on mine, but i have to unmount my XA ESC's and motors and change it for normal ones, so it will take time
awesome victor, thanks for helping me this far. i have those 12 amps ESC's high speed controllers or whats it called, thats what the XA shop sells to
vadmcse
ok, tested
Unmount my FC from my 650 and mounted it on my Turnigy HAL project
4 RCTimer 40A Simonk flashed ESC.
4 Turnigy Aerodrive XP SK4240-750 motors
NO propellers
2 Turnigy Nanotech 4S 5000MAh 35-70C in parallel
Created a new profile on the FC using the wizard for a X quad with normal ESC's.
Connected and..................everything worked as expected, in all throttle range, from min to full.
So, you can test only one motor and ESC on the FC, disconnect the other 3 and test.
If the problem continues, then reflash the FC with the latest firmware. I know you already did it, but many people had problems with firmware, even after flashing many times.
If it doesn't solve the problem, test another ESC and motor, if you don't hav 4, don't worry, you only need one to test.
If you want to send me 1 motor and one esc to test it in my FC, no problem
If you want to send me the FC to test with my motors, no problem
If you want to send me all the quad to test it, no problem.
I don't know what else to do, and regards the NAZA fc, i'm sorry, i don't have one, so i can't help you with the testings.
Let me know your progress.
Victor.
ok, tested
NO propellers
Victor.
Many thanks, ill test it out with my naza, see what happens, i personally think that the FC is to blame, if i test the motor and esc on receaver there is no problem at all. as soon as i connect them on the FC all *** breaks lose, as you can see in the video.
Can you make a screenshot from the quick menu? so i can use your settings, maybe that helps a bit..
vadmcse
Here is
vadmcse
Ok, send me your Email address by PM and I'll send you a copy.
The file is not in the XA site, they deleted it.
vadmcse
Hi,
Ok, i have the 1.36 version, is the same that you already have, but if you want to give it a try...
Send me your Email address, i'll send it
