I thought I would add this here so we can separate the two systems:
Product Overview:
The YS-X4 FC is a continuation of the zeroUAV product innovation, practical, simple style and using a highly integrated IMU control board
The new All in one design is stylish appearance, has a full metal texture with free navigation, guidance and point navigation, point lock features, while supporting a variety of terminal ground stations and adapt to all kinds of frames.
The Ground Control Station comes free with any of the systems purchased and is available in Android or PC versions
Wifi Version
1 Auto (Takeoff/ Go Home/Landing)
2 Target Lock & Fly encircle (Both ground station and RC Transmitter can control &
No limitation)
3 Click/Touch & Fly To Point (Unlimited times, 30 meters Point to Point max, 20 sec
wait per completion for next point)
4 Realtime Flight status (Google Earth Map)
5 Auto-Navigation(4 waypoints + 200m Diameter Max)
6 Fail/Safe (Auto Hover–Go home–Landing)
7 Low Voltage Alert
8 Gimbal Stabilization
9 Flight Control Mode(GPS Atittude Mode/ Atittude Mode/ Manual Mode)
10 Wifi Module
11 Built-in Damper Module
12 Optional S-BUS/Ordinary/PPM Receiver
13 Carefree
14 Follow Me
15 Intelligent Motor Arm/Disarm
Navigator Version
1. Features as per Wifi version
2. Target Lock & Fly encircle (No limitation)
3. Click/Touch & Fly To Point (No limitation)
4. Auto-Navigation (8Waypoints + no range limitation )
Basic Characteristics:
Supports multi-rotor aircraft type
+4, X4 type Quad
+6, X6, Y6, Rev Y6 type rotor
+8, X8, V8 Octo (unavailable for Gimble)
Recommended remote control
PCM or 2.4GHz
At least 6-channel or 8-channel
Failsafe and support all channels
Supports ESC with a 400Hz refresh rate
Recommended type of power: 3S ~ 6S lithium polymer battery
Power consumption : Maximum 2.5W
Operating ambient temperature : -5 ° C to +60 ° C
Assistant Software system requirements: Android / Windows XP sp3 / Windows 7
Flight characteristics
Hover precision (GPS mode)
Vertical direction: ± 1m
Horizontal direction: ± 2m
Maximum tilt angle 35 °
Wind resistance <8m / s (17.7mph)
Maximum vertical speed 6m / s
Components:
1 WIFI module X1
2 main control board (MC + IMU) X1 (Black / Silver)
3 GPS module X1 (Black / Silver)
4 Power Module X1
5 LED lights X1
6 GPS bracket X1
7 Steering gear of wiring X8
8 USB cable X1
9 Warranty Card X1
10 Stickers X1
11 cable labels X1
Bluetooth is available as an optional extra
Product Overview:
Wifi Version
No limitation)
7 Low Voltage Alert
10 Wifi Module
13 Carefree
14 Follow Me
Navigator Version
+4, X4 type Quad
PCM or 2.4GHz
Components:
1 WIFI module X1
4 Power Module X1
5 LED lights X1
6 GPS bracket X1
8 USB cable X1
9 Warranty Card X1
10 Stickers X1
11 cable labels X1
