Zenmuse H3-3D FPV camera through GoPro
jebleg
Hello, just joined today so please go easy on me :)
I fly a TBS Disco Pro and an S550 Hex that I built from scratch. I have just bought the Zenmuse H3-3D gimbal and attached my GoPro to the Hex - it has the USB connector to the GoPro, not the 30pin BUS.
I have trawled the internet looking for an answer to this but cannot find out how you can use the GoPro as the main FPV camera whilst attached to the H3-3D.
The only output is the 8 pin ribbon cable for use with the DJI Phantom which is no good for me.
Do I have to use a separate USB output from the GoPro to the VTX or is there a way of doing it from the gimbal that I'm missing?
Tahoe Ed
Get the FPV hub. No soldering and you can easily add the iOSD mini. You will want it. The other option is to use the 3.5mm plug into the GCU. If you do not have a GCU then you have the wrong H3-3D. One without the GCU is for the P2, the one with is for other applications.
