ksrimoungchanh
@Koptercam, Did you try it out? what was the outcome? I am also interested, since I have a S800/Zenmuse getting ready to run-up and request to clearance to take off..
I am also(was) planning on using 2x6S 6000mah to get 12000mah.
Did you start off your flight with everything on default gains? before adjusting? My WKM I am using for the S800 is currently on a F550 and the gains are really low (40s) across. I know when I hit default, it all goes to 100 and I am worried that it may be jumpy on the S800. Maybe the weight and size will have a difference.
KS
KS
Thanks again,
ive got a few things to try tomorrow! I'll adjust the vertical gains and go for another flightI was thinking the exact same with the voltage monitor... this the first DJI system ive used, as i usually use Mikrokopter FC which gives me telemetry directly to my MX-20. Can you recommend a telemetry system to use for the s800?
