Other Xiaomi Mi Drone
nathan
Administrator
Staff member
Xiaomi is getting into the drone business. The Chinese manufacturer mostly known for its aggressively priced high-end smartphones today introduced the Mi Drone, a camera-wielding quadcopter that undercuts comparable models from market leader DJI by over $300. Two models will be available: the cheaper one, priced at 2,499 Chinese Yuan (just over $380), will feature a 1080p camera, while the 4K model is 2,999 Yuan ($457).
The ball-shaped camera on the higher-end Mi Drone uses a Sony 12.4-megapixel sensor that can capture video at up to 3,840 x 2,160 at 30 fps and take RAW photos, while On the lower end 1080p model, Xiaomi has packed a 16-megapixel Sony backside illuminated CMOS and a 104-degree wide angle lens. Both feature a detachable gimbal that does 3-axis stabilization and is assisted by an optical flow sensor positioned between the camera and the battery bay on the back.
Xiaomi says the Mi drones will have 27 minutes of flying time on their 5,100 mAh batteries, with a range of of 3 kilometers. Like DJI, Xiaomi will build geofences into its drones to prevent them from flying into restricted areas. The drone will automatically return to base when its battery is dying or when it loses contact with the controller.
What do you think?
DonQD
I LOVE my xiaomi drone (1080p). Im a beginner and its so great! The app is in Chinese but you can get an unofficial english version. Both work well! I would recommend the xiaomi drone to any beginner. It really does get 27 minutes flying time and charging the battery and controller is not much more than 45 minutes!
