jfro
Aerial Fun
I maidened my x8 w/ Avroto 3515's * 15" prop at an AUW of 17.75lbs & xAircraft FC. Will be flying at 16 to 20 lbs most of the time.
I checked my vibration on the data and it was not bad even though in my rush to get maiden flight in today, only 4 of the 8 props were balanced.
My plates on my frame are 1/16" g10 and arms are VulcanUAV aluminum rectangular arms. I'm at 860mm.
Frame feels pretty stiff, but noticed when flying with 4 lbs of barbells underneath, it seems to flex a bit with the longer arms. I'm curious if went to 1/8" plate material if I would get rid of some of that trampoline bounce look Center plate has two 8 1/4 plates and a 6 inch battery top. All 1/16". I may cut the 860mm down ot around 660m which would be good for up to 16" props. I may convert this to a hex @860mm for 16" props or cut it down as an x8 at 660 to 700mm for same props.
Main use is video taping so not sure if the longer arms are good or not.
Anyway, looking for ideas/suggestions on plate size and arm length.
