mbsteed
aerial video centric
I have just finished my Octo build, calibrated orientation, used Att mode to try and take off but it immediately flipped from front to back as I tried to take off and dug into the earth. No real harm done but my stomach kind does a flip and then there is this sense of frustration and dissapointment that floods over because I had checked everything twice and all looked good.
I had individually setup each ESC and checked the rotation of the motor then as well.
I went through the setup client step by step.
I am using the Futaba S Bus connection and have an adapter for my Spektrum Dx6i, it took some trial and error to get the connections correct but all the TX sticks work as expected in the setup client.
The yellow lights were flashing indicating Att mode was good (I assume) and I just checked the rotation of the motors and the props again (at least for the third time).
I went with the default gains, I didn't change anything there.
I am using two separate batteries on each set of four ESC/motors (one powering the leds and the other the FC).
All the motors spool up as expected.
It flipped from the front to the back (front motors came over the top).
Any suggestions of things I can check? I am not sure what to try.
