fortworthrealtor
yeah both of them are 35c.. Thew batteries are correct.... I am going to take it to a open field today and try to get it off the ground without the gps.. I will see what it can do..
I also centered the GPS puck over the naza so it is set at 0,0,-10, .
I personally do not think so. My thoughts is that it is voltage/current related. Have you considered swapping the Naza in your Phantom for this one for testing purposes? I personally think it's voltage/current related, as in the motors aren't getting what they need. Are you sure all your solder joints are solid? You mentioned this all started when you had to reassemble, so that's why I'm asking.
I am wondering if this is your problem? you do know that the red line is a positive number? so you should show something like 0,0,10. I would even try 0,0,0 and see how that works out.
on number 2 that is working.. I played with that already..
How would I reflash the fireware?
Certainly if it is front heavy this will not make things any easier, try to re position your battery further back to compensate.Does anyone think the center of gavity being off could be causing my troubles.. I just put it on two five gallon bucket from right to left and it was very front heavy..
If you are not using the latest firmware then you can just upgrade another way would be to downgrade (test flight) and then re upgrade using below
1. Start the NAZA Assistant, go to Upgrade
2. Click on the blue text (No updates) next to Firmware e.g. 3.1 in the assistant under info. A pop-up box will appear.
3. Type the word 'door' there is no need to put your cursor anywhere, just type that word and another box will pop up.
4. Type 'test' for the user name and '125' for the password.
5. Follow the remaining instructions to 'upgrade' (in fact it's a downgrade) and the NAZA will be reverted.
6. After the progress bar is done, power cycle the Phantom.
7. Do a software compass re-calibration and when done, follow this by a manual compass calibration
I got this from http://www.djiguys.com/Forum/viewtopic.php?f=4&t=561
