I understand, but how do the settings from the iPhone via Bluetooth make it in to the MC? Also, I'm trying to find the directions for pairing the BT LED to my iPhone.No, the idea is that you can configure your WKM in the field without a laptop. You power on the WKM, connect with your phone or pad, and set your gains or whatever else you wish to configure. You obviously need to be with Bluetooth range, so you might go fly a while, come back and tweak gains, then go back out and fly.
Sorry Hal that I didn't understand the question. As Chris said, the LED talks to the MC via Can-Bus. All settings changes are immediate.I understand, but how do the settings from the iPhone via Bluetooth make it in to the MC?
THanks Chris! I already got it to pair! All I have to do is recalibrate the compass and set my gains for flight. I see that they added the calibration feature to the Tools menu. That's awesome as it was a pain the other way. Then I will have to set the gains.The settings are transferred via the Can-Bus cable to the MC.
Before pairing the LED with the iPhone, hook the LED (once everything is connected) to your PC with the Assistent Software to see if there is any update for the LED.
Chris
Do you have any suggestions for initial gain settings for a F550 using a 4S flat-pack battery?
Awesome. Thanks so much.Yes....the drop-down is only to choose a channel if your want to adjust the gain with your Transmitter...via LED it is much more comfortable.
Chris
Sorry... The download for what? The Bluetooth firmware is downloaded via the Wookong Software Assistant. The iPhone application is in iTunes and its called "WM Assistant". I hope I pointed you to the download you were looking for.Any chance you know where this download is? It's not listed on the support page. I did find it googling it at one point but it needed authentication like it was the "preview site" for DJI or something.
(i dont own or want an £500 iphone just to adjust gains once while in the field)
I would like to know if you CAN!!!! configure in the field with a laptop via bluetooth (with bluetooth 4 dongle for a windows machine)
anyone know categorically YES or NO have asked dji just got fobbed of with contact dealer they won't answer either
thanks anyone
