wind turbine inspection
Recommend THX-600 uav drone to you ,
Pls look at below :
Technology data
cruise speed 72 Km/h
max climbing speed 5m/s
take off and landing way vertical takeoff and landing
Distance between shafts 600mm
The size 466x466x207mm
Max take off weight 4Kg
Flight Dynamics 16000/18000mAh Li-Polymer Battery
Flight time 47 minutes (with 16000mAh battery )
Envirornment temperature sub-zero 20 ---50
Working humidity <70%
Wind Resistance ≤6 level
Electromagnetic Immunity 40Hz electromagnetic field density of magnetic current 81μ T , there is no any influence on drone and communications link
Quiet ability ≤45Dba@3m
Max flight height 5000m
Image transmission system
control distance 5 km
remote control system
transmission system (optional ) the power 100 wm , the available distance is 10 km
Pls look at below : View attachment 29050 View attachment 29051
Technology data
Technology data
if any one interested this item , pls leave messages here
