SDSURFnSAND
MultiRotor Newb!
Ok so something strange is afoot with my Naza...
A little background....due to my ESC's needing to be powered after my naza i had to make a Y harness so that i could power naza first and then esc's..
So today i go to fly and i do my normal startup sequence..power Naza and then i go to power up my esc's and the deans plug is turned around so the -end is pointing to the + on the terminal...well there was a pop like their was an arc from the battery or something...they were barely close too...but i didnt see any smoke and no burnt electronics...good to go i think...
so i plug in the correct way and only motor 1&2 powerup...3 and 4 are lifeless..damn..but thats not the end...
so thinking i just need to re-power up...i unplug everything and start my powerup sequence again...this time i get a solid yellow light from the LED on the VU...now im freaking out...I unplugg the naza from power and this time i power up the esc's first and then naza...
I get the normal start up sequence from the naza so now im thinking im good to go...NOPE...so while everything is plugged in and powered...i unplug M3 and M4 from the naza up front in the motor ports...wait a second or 2 and then i plug each one in and what do you know....M3 and M4 power up...
So im thinking whew...everything works and i didnt fry anything...so i unplug everything again and go throguh my "normal" startup...powerup naza then esc's...same thing happens...solid yellow light on VU an no motors...CRAP!
So then i try the "new" sequence...power ESC's, power naza, unplug M3 and M4 from motor ports and plug back in....Everything works...
What is going on?? Please help me to understand what happened and how i can fix it if i can...
Thank you
Thank you
