Tommy Luhr
Hello!
I got a tarot fy690, a fresh build that i am tuning right know.
I can start with my spec:
multistar 3508 14pole 700kv engines
13x6,5 propellers
Afro esc 30amp with a beta firmware for pancake motors (2013-10-29) SimonK.
3s battery
superx controller at 1,2 on all gains but height is 1,0 in gain.
I got 16 mins of flight time in windy weather with 10 000mah battery and used 9000mah. That on AUW 3200grams.
That is alright i think.
Problem:
The motors twitching and jitters like the gains are to high. But if i lower the gains the tarot becomes so slow in response and almost unable to fly.
Stil the twitches is there. The ringing sound in this motors tells me that the engines not works as they should!
I'm think this is all on the Esc. I want to try another Esc with superx and this motors.
What do you think about XL30a esc that is Xaircrafts own?
As i understand, this is a regular signal and not the ultra pwm esc?
Im i wrong here? There are so bad info on this at all stores!
Just want something that works vell. It has not to be the simonk firmware (even if that firmware was very nice to fly) but it has to be a good controller that never fails on my rig.
Sometime the afros make the frame hexa tilting just after take off, think this is a sync issue on startup!
This setup is not reliable enough to make relaxed flights with all that expensive equipment that's planned.
Please share your ideas!
/Tommy
13x6,5 propellers
3s battery
Problem:
/Tommy
