Using Spektrum DX8 with Wookong-M
Kazmandy
Hello,
I'm not able to get the motors started when putting the DX8 throttle and aileron controls into the CSC position. I have tested all motors through the wookong test facility and they are working fine, I also tested them individually, directly from the Ar8000, and they work fine. It does say in the wookong manual about: 'CSC may not start motors if trims and sub trims of Tx sticks are not 0!'
Is this referring to the trims on the DX8 or the trims in the wookong software, and indeed is this the problem ???
Please, ANY suggestions would be gratefully received !
Cheers
Carapau
It refers to the trims, both normal and sub, in the DX8. As for the reason that you are not getting the motors to start, I suspect that you might have a channel reversed somewhere. For the throttle and elevator, pushing up should see the slider in the WKM assist software move to the right. For aileron and rudder, move them to the right and the slider moves to the right. To 'un-reverse' the channel, you can either do that in the WKM software (button at end of slider if memory serves me right) or in the TX itself under servo setup.
