Unique in the world ! 5.8 GHz Receiver Module for EasyCap USB Capture
RCShutter
Founder of RCshutter
[h=1]5.8 GHz Receiver Module for EasyCap USB Capture[/h]
Unique, Simple, Easy...
Compact 5.8 GHz Receiver Module for EasyCap usb capture. 5.8Ghz Circular Polarized Antenna and EasyCap USB Capture included in this Receiver module.
You can using with any computer while flying.
Specification :
Sensitiviy is -90dBm
Voltage: 3.2v - 5.5v
Current: 170 mah
RFin: 50 Ohm
Ch1 : 5705mhz , Ch2 : 5685mhz , Ch3 : 5665mhz , Ch4 : 5645mhz , Ch5 : 5885mhz , Ch6 : 5905 , Ch7 : 5925mhz , Ch8 : 5945mhz
RCShutter
It will works with all video transmitters if freq. is same. And you can use with your computer. ( recommended notebook not netbook)
Our receiver freq list
that is pretty cool. this is non airwave,,,, what all systems does that work with?
did some legwork for ya, this works with foxtech, hobbyking 5.8 gear like rc305, rc 805.
it does not work with boscam, flycam one or airwave like fat shark, iftron
Aztech
far les lag than i would have expected! looks awesome if you had a mini quad with fpv then you could use a laptop as your entire ground station hmmm next project in the planning lol and yes what is that cable? is it the AV L R inputs? dose this add on make them redundant?
