Motopreserve
Either that is not a lipo - or they are suggesting a low discharge as 2.5 volt - which for a lipo would kill it pretty quick. Regardless, depending on the size of your MR, 1000mah won't get you much flight time.
The battery also says 10C, so if your motors draw many amps, you may (or may not) go over the 10C discharge capacity.
Looks like you you should grab a couple new batteries.
