Turnigy Rx Controlled Switch and Failsafe?
Pelted
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8833
I finally received a couple of these receiver controlled "switches" from HK. I wanted this one over a similar unit I was using simply for it's fail-safe mode of alternating the switch on and off. (Flashing lights in my case.) Everything wired up fine, very basic if you just follow the schematic. The issue I'm having is with its fail-safe mode not working. I have two of these and both behave the same way even when the jumper is set to "on/off" when entering fail safe by turning off the Tx the lights just hold last position.
Now obviously with my Futaba 8FG I can set fail-safe from the Tx to on or off, and this works, but this devices "feature" of having a fail-safe mode just doesn't seem to be working for me. I'm hoping someone here has used these and can provide some guidance, my first guess is that it has something to do with the Futaba Rx and whatever I may be doing. Unfortunately there are really no instructions past setting a jumper and wiring diagrams.
