NerV-Runna
Im getting a MK octocopter XL frame.
Im looking to use the Turnigy G25 motors.
Will these motors be sufficient???
Also it says on the HK site that I should use 14x7 props.
Should I? Or should I use the 12x4.5?
Or 14x4.5
The specs for the G25 are:
Spec.
Battery: 3~4 Cell /11.1~14.8V
RPM: 870kv
Max current: 32A
No load current: 10V/2.4A
Current capacity: 44A/15sec
Internal resistance: 0.03 ohm
Weight: 193g (not including connectors)
Diameter of shaft: 5mm
Dimensions: 78x35mm
Required;
50A ESC
3S~4S Li-Po / 10 ~ 14-cell Ni-MH/Ni-Cd
11x8 ~ 14x7 prop
Suitable for sport and scale airplanes weighing 3 to 5.5 pounds (1.4–2.5kg).
G
Or 14x4.5
Spec.
RPM: 870kv
Max current: 32A
Dimensions: 78x35mm
Required;
50A ESC
11x8 ~ 14x7 prop
G
