Jes1111, you are right, but there are a few different kinds of vibration induced by props.
The vibration caused by unbalanced prop are higher on the equatorial plane of the prop, making the bearings to wear faster. This vibration have high frequency equivalent with the rpm of engine and usually are noticed on the footage as blurry image. However APC SFs are much lighter compared with wood props, so is not is so important to be perfectly balanced, (which is almoust impossible with SF). If the frame have some decent anti-vibration feature, this micro vibration will be damped.
But, I was talking about large vibration caused by blade hiting turbulence. A flexible blade will do better than a rigid one in this situation, by bending and absorbing the shock and attenuate this kind of vibration
On the APC SF rpm limit. I had the same concern until I did stress tests with APC SFs, up to 25k rpm, mounted on a biax, after arguing with a colleague who did 5 holes in the hub section trying to balance them. I wanted to demonstrate him that the prop will break in the hub section and his wrong making holes. The prop hold and i loosed the bet. If you have an old APC SF try to break it with your bear hands on the hub section and you will see how hard they are. I'm supposing your are not Chuck Norris ;-)
