TopXGun Releases New Flight Controllers on 2017 CES
TopXGun
Shanghai TopXGun Robotics Co.,Ltd., is a global professional supplier of multi-rotor flight controller and systematic solution. TopXGun is committed to providing most performance, best experience in revolutionary flight control products and solutions for industry users and fans. New Product Category: Intelligent hardware| Artificial intelligence
·T1 Multi-Rotor Flight Controller
http://topxgun.com/en/T1
T1 flight controller is specifically designed for multi-rotor UAV, and supports all the multi-rotor structure on the market. It adopts design of aluminum case with high degree of accuracy and built - in damping,which makes UAV have a goad stability and extremely high control precision.T1 supports PC and smartphone ground station,it can achieve auto-fly.Meanwhile,SDK will be open for free in T1-S in order to support UAV manufacturer & integrator. Functions:1.All-in-one design 2.Built- in damping 3. Support SBUS receiver, PPM receiver and PWM receiver 4.Sophisticated orientation control algorithm 5. Accurate position lock when hovering 6. Excellent interference immunity to magnetic fields 7.Failsafe protection 8. Low battery alert and protection 9. Protection for one-rotor failure 10. Point-to-go function 11.Support high-performance with external IMU.
·T1-A Agricultural-protection flight controller
http://topxgun.com/en/T1-A
T1 - A is a mature flight controller for agricultural UAV. It provides rich and practical function that can meet the multiple requirements of the current agricultural UAV. By the integration of high precision sensor, the application of advanced industrial precision calibration algorithm as well as reasonable intelligent operation mode, the more efficient, accurate and convenient way of plant protection work can be realized. Functions:1. Multi-opration modes: AB point operation, semi-automatic operation and manual operation 2.Suitable for eleven kinds of commonly used multi-rotor 3. Terrain following radar module 4.Liquid level sensor 5.Precision spraying 6.Break-point continued to spray 7.Dose monitor
·T1-S Double Redundant Flight Controller
http://topxgun.com/en/T1-S
TopXGun T1-S is a flight controller designed for professional multi-rotor UAV, which is 7-core Double Redundancy. Not only improves control precision, but also provides more professional protection to UAV. Functions: 1.Dual backup structure 2. Double GPS compass, high Positioning accuracy 3.Support 2-12 battery 4.Black box function
·T1-PRO Double Redundant Flight Controller
http://topxgun.com/en/T1-Pro
TopXGun T1-PRO flight controller provides a 7-core dual-backup system that integrates high-precision industrial-grade sensor components, using advanced temperature compensation algorithms and industrial-grade precision calibration algorithms to enable the system to play an accurate, stable and reliable performance. Functions: 1.High performance external IMU 2.Seismic structural design; 3.Temperature compensation; 4.Dual backup structure 5. 2 ~ 12S high-voltage power management module 6.Black box function
·TOP-D1 Differential High Accuracy Flight Controller
http://topxgun.com/en/TOP-D1
Top-D1 flight control system is a designed flight controller with differential and high precision for UAV. To get a centimeter level accuracy, it integrates the industrial-grade high-precision sensors, high integration differential module in compact type and high precision air antenna. Functions: 1.Positioning in centimeter level 2.Airborne aviation differential GPS antenna 3.Industry-grade solutions 4. Black Box function.
·K3000 Multi-Rotor Dynamical System
K3000 is especially designed for plant protection drone. It contains M60 motor, E80HV electronic speed control and P21 propeller. It has a strong load capacity and excellent reliability. Functions: 1.Massively loaded 2. Portable and efficient 3. Excellent reliability.
·K5000 Multi-Rotor Dynamical System
The multi-rotor dynamical system K5000 is especially designed for plant protection drone. It contains M80 motor, E80HV electronic speed control and P30 propeller. Considering the features of plant protection drone, K5000 works more efficiently and stably after we optimized it in load performance, efficiency and reliability. Functions: 1. Massively loaded, Superior performance 2.Durable, stable, applicable to all kinds of environments
·2.4G Wireless Datalink
2.4GHz wireless datalink is composed of the airborne terminal and the ground terminal. It is used for the wireless data transmission between the flight controller and ground station software. Functions: 1.Stability and Reliability 2.Multi-platform ground station 3.Easy installation and simple to use.
·Optical Flow Sensor
TopXGun optical flow sensor is mainly used for visual positioning, which can make the unmanned aerial vehicle (UAV) to achieve precise positioning and stable flight hovering in the absence of the GPS signal. Functions: 1. High performance sensor 2. CNC Cooling shell 3.Perfect match with topXGun flight controller TopXGun has set out to Las Vegas, and they will spend 21 hours on the plane till 1/3/2017.For most of them, this will be an exciting and challenging journey.Find us on CES 2017 on 1/5-1/8, let us make an appointment! We are waiting you at Las Vegas on Sands Expo, Level 2, Halls A-D 46530.
Website: http://topxgun.com/en/. If any question,please don't hesitate to email us sales@topxgun.com.
TopXGun
Have fun on CES! let us show you tips on your journey.
1st series
AF1QipMzTtqYOl_HCiGj5fAQf9XjweijHWMMkZC2ktkn
CES is the world's largest consumer technology trade show. 2017 is the 50th anniversary of CES. CES focuses 150 countries and regions, with more than 3,800 companies exhibitors, and 2.4 million square metersbooth area. 6,500 media will attend this annual event and it will be open to the public at 10 am on January 5.
CES is a leader in consumer technology products, with artificial intelligence, machine learning, computer vision, virtual reality, hybrid reality,autos, robots and popular unmanned aerial vehicles.In addition, there are a lot of keynote speeches, industry conferences, forums and other professional content.
Let TopXGun show you around!
CES exhibition is divided into three major exhibitions: Tech East (mainly Las Vegas Convention and Exhibition Center) , Tech West (mainly Venetian Hotel Sands Convention and Exhibition ) , Tech South (city-center-based).
The famous home appliances, chips, cars, games and other manufacturers gather in the Tech East, and Tech West focuses on a relatively "niche" of consumer electronics technology companies. In the Sands Expo Center (in fact, this is a very large exhibition center), you can see the 3D printing, health technology, robotics, intelligent equipment and many other small and medium-sized enterprises who display technology products. Tech South focuses on media and advertising companies in the consumer electronics industry.
TopXGun
Our team on 2017 CES.
TopXGun
Our technician's professional operation in hot summer.
TopXGun
